Vent Visors? Bugguards? Air deflectors?
Does anyone use Ventvisors, and air deflectors on their rigs? I was considering vent visors for the doors but can't decide how they would look if i were to take the top down. I decided against air deflector for the hood.
They are made by Vent Shade. Yes, they are in channel. You will need to put another layer of double sided tape on them because one layer is not thick enough to make contact with the inside of the run channel. I like mine. Make sure you install them in warm weather.
I've had them on almost every vehicle before this Jeep, but didn't get them for the Jeep simply because I carry the door by the window hole, and these get in the way. If you aren't taking your doors off regularly, then I wouldn't have any problem with them.
I have Weathertechs on my rubi. Don't require tape, snap into channel. Take about 10 minutes to install all 4 doors. I have my windows in the down position prior to removing the doors. Stick one arm through window and grab arm rest and the other on the outside grabbing the bottom front corner. Come in different tints.
