Viair vs. ARB
OK...any opinions regarding these two OBA compressors? I don't have lockers yet, so don't know which option I will be going in that department. I just want to be able to go the air locker route if I decided to. The main purpose for a compressor is airing up for now...
Thanks much
Thanks much
for tires only go w/ viar. The locker option complicates things a bit. The arb air lockers run off actuators that tie into the compressor. I know there is a hookup to run arb's off a power tank but am unsure if there is one for viar. I cant imagine there isnt but its something to consider. If the option is there deff go w/ viar. Its a heavier duty compressor and adding a holding tank is simple.
There are many companies making adapters for the ARB lockers to be run off of other OBA sources. I know that Kilby has a kit for OBA systems specifically designed for ARB air lockers, so I would go with ViAir between the two options mentioned.
