VIAR OBA confusion
I received my new VIAR OBA compressor Thursday and was hoping to install this weekend but the package was missing the mounting bracket. I contacted Brett (jeepswag) and he said he would get one shipped out to me on Monday. I notice that the compressor I received was also missing the grey looking cap at the front end...not sure if this piece has any function but mine is different then all the pictures and videos that i have seen. There aren't any installation instructions that came with it so I have been reviewing the video links which don't help me much as far as the electrical goes. There is a VIAR fuse block and in-cab switch that came with the package but installation videos don't go into how this is connected. Also It looks like I attach the "nipple" for the air hook up on the end where the grey cap is missing but I'm thinking I will need some longer hardware to attach it. Does anyone have some electrical advice and do I need the grey endcap?
There isn't a valve for regulating air to the tank so you can use it just for tires. I've got e lockers so never got a tank for my setup. Works great as is. I'd only get a tank if I was running air tools or lockers.
You will love this setup on the trail. Saves a lot of headaches having your own pump.
The gray/black caps that screw on the ends are air filters.
The relays actually turn the compressor on and the pressure switch cuts it off/ on when PSI is reached.
The braided hose is your output with a check valve in it.
Are you running a tank?
Here's how mine is set up with a tank. If you need some more detailed pics I can get them.
As I was waiting on the mounting bracket to be shipped I used the black tubing for the in cab air fitting. I'm thinking I would have to buy extra tubing if I was to mount a fitting in the cab and run it to the compressor fitting.... I probably don't need to do this or does it make it more convenient to have the fitting in the cab?
