Viberation highway speed
Old 08-21-2016, 08:31 AM
Jeepstercanada's Avatar
Issues started after jeep did my front axle seals under warranty
Old 08-21-2016, 08:46 AM
Biginboca's Avatar
Then you should take it back to the dealer for them to fix. They had to disconnect your front driveshaft from the diff and also pull the front diff gears out to get to the seals. Sounds like they didn't put it back together correctly.
Old 08-21-2016, 01:28 PM
Ya I did they told me it was tires, tires 6 months old
Old 08-21-2016, 03:08 PM
kmrtnsn's Avatar
What tire pressure are you running?
Old 08-21-2016, 03:14 PM
30 running 35x12.5/15 cooper stt pro
Old 08-30-2016, 02:44 PM
Fafafofi's Avatar
Originally Posted by BODACIOUS
I had this wild speed wobble as appose to "vibration". I went across the street to the local mechanic and they just replaced this ladies front end from the same thing .Called it "DEATH BY DODGE"!!!! Turns out there is a whole ton written on it .Huge ongoing problem. You hit a big bump at speeds from 45-55 mph AND BAM!!! It feels like the front wheels going to fall off.You either drive out of it (impossible) or stop .It happend within a week of me buying my 08 jku with 297,000 KMs on it..Took it back they said everything was tight as could be (and they passed the safety with no horn & parking break).Happened 2 weeks later again. SINCE PUTTING 20" WHEELS WRAPPED IN 35" MICKEY T DEGAN 38s I'VE NOT HAD THE PROBLEM RE-OCCUR since June .Go figure. I had waited to get it fixed as i was about to do a lift,but now Im really confused!!!!
Previous owner on my JKU had death wobble. Replaced all sorts of steering components and still couldn't figure it out. Still bought it and I put new shocks on all around and it was gone. I sorta feel bad for getting the Jeep at such a low price but it also sucks if your mechanic knows jack sh*t and can't fix your ride.
Old 08-30-2016, 04:24 PM
Turns out when jeep had my front diff apart under warranty they never tightened the front pinion so lots slop in pinion. Going in Friday to see what they will do for there **** up
Old 09-01-2016, 06:48 AM
Ajkaz's Avatar
Depending on how far you drove with it like this, they should agree in writing to address any future pinon bearing or pinon seal issues on the axle at no charge. That kind of play can destroy that bearing and its not an easy fix.
Old 09-01-2016, 09:13 AM
Ya my front locker no does not work either
There putting in new gears and hearings won't take no for answer
Quick Reply: Viberation highway speed
