vibration
Old Sep 23, 2009 | 11:03 AM
ckmehl's Avatar
Default vibration
ok this one might take a little to explain.
i put my new drive shafts on. front is a coast and rear is a Trailmaster. now before i put them on i did not have a vibration. now i do. at first i thought it was my tires. New MTR with Kevlar. they are on 15" wheels. so i aired them down to 32 pounds and the vibration got worse. but once i get up to about 35 mph the vibe almost goes away. now i have not had it over 40 mph since i put the shafts on. i'm working with Trailmaster right now on this. could my alignment be a cause for this. it is off alittle. all of my mods listed in my signature are all recent. any help here would be great.
Old Sep 23, 2009 | 11:06 AM
if it happened right after the drive shaft install and wasn't there before i think you answered your question.
Old Sep 23, 2009 | 11:08 AM
ckmehl's Avatar
Default think
i think the rear shaft might be out of balance. but i dont know about the front. how would i know if the front is off not the rear.
Old Sep 23, 2009 | 11:20 AM
remove the frt one and go for a ride. is its still there then its the rear. i would still try with just the front shaft as well
Old Sep 23, 2009 | 12:04 PM
RCJeeper's Avatar
How does the front pinion angle look? Is the DS within 5° or so of the pinion? I had a bad vibe in my front DS and just recently got a handle on it. Changed the pinion angle by increasing the lower control arm length and lengthening the uppers.
Old Sep 23, 2009 | 12:58 PM
fullthrottle's Avatar
did you install the new tires at the same time
Old Sep 23, 2009 | 07:35 PM
ckmehl's Avatar
Default nope
they were on before the lift, and drive shafts
Old Sep 24, 2009 | 11:11 AM
CitadelJeep04's Avatar
Did you install the lift and driveshafts at the same time?
Old Sep 24, 2009 | 11:17 AM
kflash's Avatar
I will tell you that though many claim to have no vibe at all, I still have the slightest at 40 mph that I have chosen to ignore. I have shafts rebalanced and rebuilt. There just isn't any way to get past the inability to adjust castor independant of pinion angle. I have had my castor at 2 degrees and still had a slight vibe (though it was less), but you wouldn't wan't to drive it that way. I have also had castor at 5, 6 and 7 degrees. I currently have about 4 inches of lift (3 inch teraflex on a 2 door).
Best of luck, and let me know if anything works.
