Vibration
Old Oct 5, 2012 | 08:07 AM
jk958's Avatar
Default Vibration
Hey guys,
Been away from the forums doing my mods on my jk..,
Here is what ive done so far ;
King OEM adjustable shocks
Teraflex lift
Teraflex front and rear adjustable control arms
Aev pintler wheels on BFG AT KOs
4.56 regearing ...
Now the problem is I have an annoying vibration going through 80km/h and it stops,,, again when decelerating the vibration becomes more violent then stops at 70km/h , Ive done steering alignment ive done tire balancing and again the vibration is still there .
2012 jk 2dr
Plz help
Old Oct 5, 2012 | 08:11 AM
wayoflife's Avatar
JK-Forum Founder
does the vibration oscillate or is it constant and, do you feel it in your steering wheel only or, can you feel it throughout your entire jeep?
Old Oct 5, 2012 | 08:21 AM
jk958's Avatar
Its constant, through 80kmh accelerating , through 60 decelerating
Its through the entire car
Old Oct 5, 2012 | 08:23 AM
wayoflife's Avatar
JK-Forum Founder
okay, just to make sure, is the vibration significant like a shimmy or, very light like a buzzing?
Old Oct 5, 2012 | 08:31 AM
jk958's Avatar
Like a buzzing
Old Oct 5, 2012 | 08:33 AM
wayoflife's Avatar
JK-Forum Founder
Like a buzzing
okay, could be you have a rear pinion angle in need of adjustment or drive shaft in need of balancing or replacement. could be a front shaft but, being that you have 2-door, i'm gonna go with it being a rear. could be wrong though.
Old Oct 8, 2012 | 05:23 AM
DaBins's Avatar
Default vibration
Hey,im having the same damn problem!! i cant seem to figure it out,in the beging i thought my wheels need alignment but apparently its not! if any of you know whats causing this please share...
Thanks...
Old Oct 8, 2012 | 05:46 AM
HLKSTER's Avatar
Thanks...
Like wayoflife said its probably a pinion angle problem...
Old Oct 8, 2012 | 08:15 PM
jk958's Avatar
Thanks...
GOT IT FIXED !
I was really annoyed by the vibration then i took it to the place where i got it fixed , and guess what , the pinion itself was bent ! so littile but we could see the drive shaft wiggle slowly, got a new set of ring and pinion fixed
Thanks wayoflife !
