Vibration at highway speeds..advice?
Old Mar 3, 2008 | 04:23 PM
JLightning9's Avatar
Default Vibration at highway speeds..advice?
Newbie here,
I installed my teraflex BB lift and added my new wheels. I test drove them locally and everything was fine. Then I hit the highway....at high way speeds, 55 and up, there is a very noticeable vibration. My buddy told me that it is probably a wheel that is not balance correctly. Later this week I am going to swap the spare with the one that I think is causing the vibration.
If this does not work...what do you suggest?
Old Mar 3, 2008 | 04:44 PM
goose244's Avatar
Its a wheel balance problem. I would put money on it!! Take it to a GOOD shop and have them check the tire balance. Big tires are hard to balance and usually require alot of wheel weights.
Old Mar 3, 2008 | 04:54 PM
BaltChief's Avatar
The Trixius MT's will not ride as smooth as your stock tires. I have also heard they are hard to balance.....so that is my guess
Old Mar 3, 2008 | 04:56 PM
CLACKEY(_!_)'s Avatar
I'd put money on a tire out of balance.
Old Mar 3, 2008 | 05:03 PM
That eases my tension. Thanks for the consensus.
I will swap with my spare and then take the unbalanced one to the shop. Anyone know a good shop in the Boston area?
Old Mar 3, 2008 | 05:18 PM
mcnaught6's Avatar
have them all re-balanced. there is no way to know which one is wrong just by looking (unless it looks like one of the weights has fallen off). all tires require different amounts of weight. there is even variation from tire to tire (even if the brand and size are all the same).
Old Mar 3, 2008 | 05:49 PM
I am pretty sure I know which one it is, because I can limit it down by elimination. I have sat in both ides of the jeep at high speeds and it is definitely on the passenger side.
When driving I do not feel it in the steering wheel at all, so I will start with the rear. I cant take it to a shop during the week anyway, so trial and error is the way to go, no?
Old Mar 3, 2008 | 05:55 PM
BullsJK's Avatar
Did you check to make sure all of your lug nuts were tight after they did the work? Could also cause a vibration as it could also be widdling your lug stud threads Not like I know from experience or anything though
Old Mar 3, 2008 | 08:58 PM
militiakrawler's Avatar
Could it be driveline vibration due to the lift increasing the angle at t-case?
Old Mar 4, 2008 | 04:40 AM
we tightened them when we were done, then drove around for a few miles, and re-checked.
It is definitely on one side of the jeep. If it was anything associated with the t-case wouldnt it be less isolated and more prominent?
