vibration from rear end
Old May 13, 2016 | 07:21 PM
Christian13's Avatar
Default vibration from rear end
Hi, I'm hoping someone can help. For reference my current setup is 3.8 auto with 5.13 gears and stock drive shafts, 4" lift and pinion angle set the same as t-case (7 degrese). I usually run 35s when I go wheeling and my stock wheels tyres driving around town, this isn't much of an issue for me because I never need to go faster than about 90kph / 56mph. However since I had my gears done I have noticed a very mild vibration when travelling at 80kph / 50mph or faster only when I have my stock wheels tyres. Is this because the drive shaft is spinning to fast?
Old May 14, 2016 | 01:40 PM
JK08MCS's Avatar
Ever sense I installed the new control arms, I have had this issue. In theory I was going to set the axle back a 1/4 in. so the wheel would be center of the bucket. Think the axle is to be set 1 degree lower for be under load (torque).
PS: Im in hunt for a accurate angle gage, 1/2 degree increments would be nice
Old May 14, 2016 | 04:32 PM
kjeeper10's Avatar
Vet Army
You should have the pinion -2° lower than the driveshaft.
Old May 15, 2016 | 02:02 PM
I'm still running a stock drive shaft, is that measurement still applicable or only if you have a double Cardin shaft?
Old May 16, 2016 | 02:00 AM
kjeeper10's Avatar
Vet Army
Double carden but helps w/ the stocker also.
Old May 16, 2016 | 08:01 AM
jimhut2000's Avatar
Vibration in the rear end! You're putting it in the wrong hole!😜😜
Old May 16, 2016 | 08:25 AM
tarpon4me's Avatar
JK-Forum Ambassador
Do you have vibration with both sets of tires? I know you said with stock at a certain MPH, but I want to make sure. (eliminate a wheel being out of balance)
Are you positive it's in the rear? (maybe a front driveshaft ujoint going bad? May be hard to tell front/rear. 4" lift with a stock front DS it's just a matter of time before you throw a Ujoint) I'm guessing you have an exhaust spacer...
Have you checked your rear driveshaft for signs of damage? Could possibly be ever so slightly bent.
Also, check the torque on the driveline parts. While you're under there, retorque everything just because. LCA, UCA's, track bars, etc...
Lastly, it could just be a driveshaft out of balance. With everything rotating faster, Where you may have had the vibration at say 65 before, it may be prominent at 50 MPH now. This is honestly what it sounds like since it only does it with the factory size wheels and tires. However, it could be any of the above.
Old May 16, 2016 | 05:11 PM
From my experience so far it doesn't seem to come from the 35s and at first I did put it down to a wheel balance issue but usually wheel balance issues are within a speed range so when you get past it it then goes away where as my issue seems to get worse the faster you go.
I know it is definitely not a front drive shaft issue because my stock front finally exploded and I was running without one for about a month while I was waiting for my new one and the vibe was still there.
The only sign of damage on my rear is a slight rub mark where it touches the fuel tank at full flex, it is possible that this could be an issue.
I'm leaning towards your last suggestion that the drive shaft is out of balance as everything else seems good.
Do you think it will help if I set my pinion angle closer to inline with the drive shaft as mentioned in the above post?
Old May 17, 2016 | 03:44 AM
tarpon4me's Avatar
JK-Forum Ambassador
It's worth a try, but if you've got a DS out of balance, I don't know that it will solve the problem. Based on your input, I think you've narrowed it down to an out of balance DS>
Old May 17, 2016 | 02:12 PM
So I'm thinking that it was out of balance before I did my regear and now the shaft is spinning much faster I'm now noticing it. This is annoying, would it be worth having it rebalanced or just get a new one?
