vibrations
This problem started when I got new gears. I also ordered some Alloy front chromolly shafts. The front shafts didnt fit, so they put my stock shafts back in. I just noticed that diff fluid is sprayed all over my driver front wheel well. I dont know how this could cause the problem, but it does seem unlikely that the tires just happen to loose balance at the same time. I cant see any sign of a lost tire weight.
In any case, I am taking her back to the shop...
look at the drive shafts see if the flanges are tight, and flush, they may have not gotten them flush and snug....hopefully they didn't pull the driveshaft apart without index marks, and put back together putting out of phase causing shaft to be out of balance......as far as the oil hopefully they didn't damage the seal when they were putting in the new shafts, and you just have a little run off when they pulled them apart, and slinging a little oil.........your profile doesn't say if you have a lift...and have them check the hub flang bolts when they put the front axle shfts back in make sure all tight, and no movement......
