warn powerplant quit, help
Old Oct 26, 2009 | 07:55 AM
ARubicon's Avatar
Default warn powerplant quit, help
went to use my powerplant this weekend, it spooled out fine with remote and then when i went to spool it in .... nothing. The red light on the remote blinks and nothing happens. Is this something simple I can fix? Can someone help me?
Old Oct 26, 2009 | 09:57 AM
Muffins's Avatar
I maybe mistaken, but doesn't the red light mean overheat? If it hasn't been overworked maybe the blinking red light means some type of internal fault. Also, you may want to check the fuses and the clutch engagement.
Old Oct 27, 2009 | 08:10 AM
Phishjeep's Avatar
Buy a smittybilt or rugged ridge!
Sorry, couldn't resist. Warn should be able to help. Good luck.
Old Oct 27, 2009 | 08:14 AM
Northridge4x4's Avatar
Sponsoring Vendor
call warn they have the best customer service and they will be able to help.
David
Old Oct 27, 2009 | 10:48 AM
robin's Avatar
David
good advice
Old Oct 28, 2009 | 05:56 AM
ARubicon's Avatar
i talked to warn c/s it was no big deal the thermal sensor went out. it was a super easy fix, took about 10min to fix.
Old Oct 28, 2009 | 06:10 AM
Piginajeep's Avatar
yeah, mine went out as well, Warn still covered the issue, even being out of Warranty
Old Oct 28, 2009 | 07:02 AM
opdsgt's Avatar
Please....
Old Oct 29, 2009 | 05:47 AM
tgrt's Avatar
Former Vendor
Can you share any details?
Old Oct 30, 2009 | 09:23 AM
grnmonsta's Avatar
There is another reason for the powerplant, air! Believe me otherwise I would buy a much cheaper one.
