Warrior Doors
Is there a way to make these doors fit tighter so they dont rattle? Mine rattle on the stricker plate BAD! Seems real lose mybe i am missing something. The latches seem to be lose when you latch them on the stricker plate. If i tape the stricker plate this takes the rattle out. Help me out
Is there a way to make these doors fit tighter so they don't rattle? Mine rattle on the striker plate BAD! Seems real loose maybe I am missing something. The latches seem to be lose when you latch them on the striker plate. If I tape the striker plate this takes the rattle out. Help me out
yendor65 blaaaaa
If i cant read a post why bother to post. ?? Some of us are useing blackberrys which dont help. CAN YOU READ THIS
yendor65 blaaaaa
Take a short piece of hose and split it lengthwise and put it on the striker. Experiment with various thickness and diameters until you find what works best. Vacuum hose might work well.
When you decide to put thee hard doors back on, store the pieces of tubing in one of the hard door storage pockets so you will remeber where they are next time you need them.
yep pretty much what everyone else said. also try the supplied shims a little up and down cured my problems completely. either way w/ 37" swampers, no doors, no top(or bikini) and the radio up, i cant hear a thing.
is there a way to make these doors fit tighter so they dont rattle? Mine rattle on the stricker plate bad! Seems real lose mybe i am missing something. The latches seem to be lose when you latch them on the stricker plate. If i tape the stricker plate this takes the rattle out. Help me out
