Waterproofing your Clutch/Transmision
Old Jul 8, 2009 | 10:27 PM
DDT713's Avatar
Default Waterproofing your Clutch/Transmision
I have an 09 unlimited with the 6spd manual, and i've heard that if the trans is underwater then you can't depress the clutch to change gears because the water will ruin the clutch and you will have to replace it. If so how would one go about in waterproofing the clutch and transmission?? Would this be a good idea??
Any help and knowledge on the subject is appreciated. I wanna get wet, but don't want to have to buy a new clutch if I have to change gears in the water/mud.
Thanks
Old Jul 8, 2009 | 10:35 PM
rcdude3's Avatar
i dont think there is a way to seal it. lol just get in the right gear before plunging in and hope you dont need to shift.
Old Jul 8, 2009 | 10:38 PM
bigbluejk's Avatar
I don't think it is being underwater that really causes the issue it is the nasty stuff in the water. But I could be totally wrong about that. I always go slow through water and if you need to shift your tranny then you really need to just slow down. Just my opinion. I live in fear of holes that are too deep and hydrolocking engines. I creep through water with my hand on my key. lol
Old Jul 8, 2009 | 10:46 PM
rcdude3's Avatar
i have noticed that the JK tranny is fully Syncronized cause if i get readu to shift i can go from 3rd to 4th the when i am ready go from 4th to 5th and so on with out using the clutch. i mean if needed you could jam it into gear. OR kill it in gear shift to higher or lower then start the engine with out depressing the clutch.
Old Jul 9, 2009 | 02:42 AM
smuhhh's Avatar
You have to depress the clutch to start the engine
Old Jul 9, 2009 | 05:09 AM
paramaniac's Avatar
Originally Posted by GoodysGotaCuda
Not in 4-lo i understand
you are correct. in 4-LO a 6 spd manual can be started without depressing the clutch
scottrock's Avatar
You are correct, you do not need to depress the clutch to start the engine in 4L
Old Jul 9, 2009 | 06:03 AM
bOLsAK=3's Avatar
That's so you can start your way out of trouble in case your engine fails.
Old Jul 9, 2009 | 07:45 AM
DDT713's Avatar
I'm Worried about having to reverse out of somewhere
Old Jul 9, 2009 | 08:02 AM
DDT713's Avatar
I'm really looking for a better solution then 4lo. I want to be able to romp through water lol and not have to worry about it.
Does anyone know anything about waterproofing a clutch? I Don't know where the vents are but i feel like you could just seal them up somehow and you would be good?
