weird noise issue
Old Apr 1, 2012 | 04:34 PM
Default weird noise issue
Yesterday after pulling out of the store, i noticed a clunking noise above 30mph and gets faster the faster i went. when i let off the gas it goes away though. i shook the tire to see if its a wheel bearing, and it didnt move. i took the front ds off to see if it was a u joint, and it still does it. i did notice the front driverside lca bolt was a lil loose so i tightened it up but it still did it. i ended up taking the lca off and the greaseable end has a lot of play to it (rc adjustable lca). could this be causing the issue?
any help would be greatly appreciated, im stumped....
Old Apr 1, 2012 | 04:56 PM
sick jk's Avatar
Do you have Rock sliders. Might sound weird but I had the same exact issue. It ended up being my body mounted sliders were hitting the frame. Funny thing is ,it only did it when I was on the gas.
Old Apr 1, 2012 | 05:19 PM
no i dont have any yet, on the list of things to get
im also wondering if it could be the cv's in the rcv shafts?
they're only 4 months old and have plenty of grease
Old Apr 2, 2012 | 08:43 AM
since only does it under power, i wonder if it could be the rear ds?
Old Apr 2, 2012 | 03:51 PM
tattedfire's Avatar
Could possibly be the cv in the rear driveshaft. Start by taking it off and put your TC in 4-hi that way you can have front wheel drive at the point and take it around block and see if the noise is gone
Old Apr 3, 2012 | 09:19 AM
i took it to the local offroad shop today ORi, so they can figure it out and do a few other things i had layin around waiting to go on
the front of the tcase was leaking so im hoping that the bearing didnt go and the slap is the sound of a stretched chain
Old Apr 7, 2012 | 08:42 AM
pulled the diff cover off the rearend and the pinion shaft has some play, and the ring gear is missing 5 or 6 teeth...
Old Apr 7, 2012 | 12:53 PM
tommyluv78's Avatar
Stock or aftermarket?
