Weird Power Loss on Sand Hills
I have a question about power. I went wheelin last weekend. It was the first "real" wheelin trip for my JKU. Everything worked great when I was climbing on a sandstone hill. In the deep, soft, sand hills you cant crawl up them though, you need to get after it a little bit. Once the tires start spinning a bit or lose traction here and there the Jeep just puked its power and didnt want to go anymore. If I disable the ESP for those sandy hill climbs would that prevent the power loss and "limp mode" effect? I didnt mind the ESP during times on rock, it actually helped a bit and didnt cause any problems, but I was crawling nice n slow too. It just sucked trying to get up the sand hills. There were a couple that I had to find another way around. My friends built up Land Cruiser made it easy (of course) and my other friend made it fine in a stock Toyota Tacoma. Not my JK though :( I havent found a thread to answer my question. Thanks for any help guys!
Originally Posted by Philip *AZ*
(Post 3676628)
... If I disable the ESP for those sandy hill climbs would that prevent the power loss and "limp mode" effect? ...
Yes this is your traction control kicking in. It's sensing wheel spin and possible steering angle changes and chopping the throttle to maintain control. There are threads on disabling this feature her on the forum.
Here is one I found https://www.jk-forum.com/forums/modi...ut-off-267851/ |
(Post 3676635)
Yes. Or, just put it in 4WD low and the Jeep will automatically disable it for you (you should see the light come on).
Originally Posted by v8zracer260z
(Post 3676641)
Yep, that traction control is a pain in the sand and our electronic pedal doesn't help either when you put it all the way to the floor.
Curious- what tire pressure were you running? Usually dropping the pressure will help the jeep 'float' for lack of better words. Sent from my DROID4 using Tapatalk 4 |
Your Jk is a drive by wire vehicle, there is no direct link from the gas pedal to the throttle body. This all done by your computer based on inputs it receives it may modify what you are telling it to do. This system is what allows it to cut the throttle and apply brakes when it senses you are out of normal driving parameters to regain control of the vehicle. It is a huge safety step forward on the road and prevents a lot of rollovers. This is not always the case in certain off road manuvers and hence the need to disable it in your case.
Originally Posted by karls
(Post 3676657)
Curious- what tire pressure were you running? Usually dropping the pressure will help the jeep 'float' for lack of better words. Sent from my DROID4 using Tapatalk 4 http://youtu.be/-3Sr0Tyy_T0 ^^^^^Hope this link works^^^^^ |
Right V8. Like I said before too, I like it on road and it did help a little as you can see from the video. Its a PITA for sand though..lol.. I found about the DBW "feature" and wasnt too happy about it. Mainly because of all the crashes it may/may not have caused in other vehicles. There is a kit you can get to help improve the sensitivity of the DBW, but I just cant see paying that kind of money for it.
Thanks again everyone for your help. Im excited to get that switch in.
