Weird whining noise after lift
Just installed a 6 inch rough country long arm on my rubicon and installed new rough country drive shafts. Today I just got a real loud whining noise when I'm moving. When I stop the noise stops. Didn't do it until today. My guess is the driveshaft but I may be wrong. Anyone have any ideas or experience on this issue??
With drive shaft as close as possible to avoid vibration if not you could damage
Transfer case. This is done with Adj control arms upper or lower , witch with that
Tall of lift I assume you have right...?
With after market Drive shafts your pinion with the yoke on it needs to be lined up With drive shaft as close as possible to avoid vibration if not you could damage Transfer case. This is done with Adj control arms upper or lower , witch with that Tall of lift I assume you have right...?
Yeah it does.
Alright so I'm not very knowledgable on drive shafts. First time I put them on since my last jeep only had a four inch lift. I took some pictures. Maybe that will help. I'll try to get a video. Their is a consent by subtle whining noise but then a random loud whine will occur but stop.
Lol - pics of the components, not the jeep. The control arms, one at the pinion end of the driveshaft and one at the tcase end of the driveshaft. (so we can see the angles they sit at.)
The problem up front is that pinion angle is directly tied to caster angle. As the pinion tilts up, the caster lowers, and the handling gets flighty. As you lift higher, you get into a situation where you have to start deciding between good pinion angles (driveshaft joints) and good caster (steering). At 6", it can be an interesting choice.
Have you crawled underneath and actually looked at the driveshaft? Did you install it yourself? If so, did you torque the pinion nut properly? If you push/pull up and down on the pinion, does it move? Have you tried pulling it off and driving without it? You can do the same for the rear to eliminate it.
Do this. Pulling the front driveshaft is what isolated a chirping birds sound for me this past summer while in the Great Smokies. If you pull the rear, drive around in 4WD (effectively front wheel drive). Are the driveshafts lifetime lubed? If not, did factory lube them?
