Weird wobble at low speeds
Old Jun 2, 2015 | 04:18 AM
frecks10's Avatar
Default Weird wobble at low speeds
I have a 2007 2dr jk, i recently did all 4 ball joints which I thought would fix this wobble. Wobble starts when I hit a bump and going around 40 if you slow out the wobble gets worst and worst but if you speed up it goes away. Anyone else experience this ?
Old Jun 2, 2015 | 02:04 PM
Nomadic-JK's Avatar
Could be a number of things, really. Is your tie rod bent? This will toe in your alignment and cause that wobble. I would suggest checking that first, followed by getting an alignment from a shop who can do it right. JKs are super finicky when it comes to the front axle setup, and if it's not set just right it will throw little tantrums. A better steering stabilizer will help mute the wobbles, but its not fixing the problem.
Old Jun 2, 2015 | 05:07 PM
D_engel's Avatar
thats death wobble. Watch planman's videos on identifying the root cause.
Old Jun 2, 2015 | 06:17 PM
jeepmojo's Avatar
Default check your track bar
stock track bars are junk on jeeps at least make sure its 125 lbs of torque on those bolts or it will cause a shake or the death wobble if theres movement
