Weld-on sliders?
Old Feb 1, 2009 | 06:49 AM
Slacker's Avatar
Default Weld-on sliders?
Was planning on making some sliders and just wanted to know if there is a reason why I can't find any that weld on on this forum. The frame looks strong enoungh to weld to. Is it just nobody wants to weld to a new jeep or none of the venders are offering a weld-on kit?
I could always cut them off and grind the frame and repaint for resale reasons.
Old Feb 1, 2009 | 07:17 AM
Suffolk JK's Avatar
Because if any part of it ever needs replacing, removing some bolts is easy. Cutting away at welds is not.
Old Feb 1, 2009 | 07:22 AM
wayoflife's Avatar
JK-Forum Founder
off road evolution offers a set that get welded on.
Old Feb 1, 2009 | 07:28 AM
Bodo's Avatar
I think Woods has some also. Jeepswag.com
OOps. Not sure if you have a Rubi with stock sliders or not.
Old Feb 1, 2009 | 07:29 AM
Slacker's Avatar
If they do it it must be ok. They make some of the parts I would most like to have.
Old Feb 1, 2009 | 07:41 AM
Robar's Avatar
Here are some pics of Ctimrun's EVO sliders.
Off Road Evolution Rock Sliders
Old Feb 1, 2009 | 07:45 AM
Slacker's Avatar
Originally Posted by YOGURT
Im building my own and I will be welding mine on. If you place your welds smart you will be able to remove very fast with a grinder, and you just cant beat the strength of a good weld.
Will you be welding a small like 1/4" plate to the frame first then the tube? Or just tube straight to the frame? And I agree welding is the strongest way to attach them. I have a 2dr so was planning on only 2 tubes going to the frame.
Old Feb 1, 2009 | 07:52 AM
Slacker's Avatar
That's what I'm talking about. I was planning on doing it just like that but with a gusset where the tube meets the plate that is welded to the frame. Those welds sure are nice might be tig. No tig here at home so I will be mig welding mine.
Old Feb 1, 2009 | 12:13 PM
Renegade's Avatar
I had some that were welded on. The only regret I had was that I didn't put on a 1" body lift first. When I did it there weren't body lifts available yet...
Old Feb 1, 2009 | 01:27 PM
RedneckJeep's Avatar
So....when are you gittin another one? I know you want one.
