what is this?
It's not the connector that is broken it is the locker actuator that is broken. If you go to your local dealer you should be able to pick it up for about $20 or so. You will need to unbolt it from the housing and install the new actuator. You will also need to pick out the rest of it from the connector on the end of the wire.
Here is the part number for what you need: 68003570AA
