what backspacing with TF 3" coil kit? please help
Old Dec 7, 2011 | 12:09 PM
PAwrangler08's Avatar
Default what backspacing with TF 3" coil kit? please help
I currently have 33's on stock wheels. Can someone tell me if I will need new wheels after I put the 3" coil lift? If so what specs on the wheels? The dealer was saying that I just need to get 17x8 or 17x9 wheels. I'm just making sure this is correct. I did eventually want to get black steelies but I have no idea what specs I need.
Thanks for the help in advance!!!
-Blair
Old Dec 7, 2011 | 12:21 PM
TeraFlex's Avatar
Sponsoring Manufacturer
4.5" or less backspacing.
Old Dec 7, 2011 | 12:23 PM
curtisc19's Avatar
Boom! There is your answer. If you have wheels with more than 4.5" backspacing, you can get wheel spacers to help them clear.
Old Dec 7, 2011 | 01:58 PM
awesome. thanks guys. this might be another dumb newbie question but i could still use 17x8 with 4.5 BS without a lift right? i would be doing this until i got all the money together to get the lift done
Old Dec 7, 2011 | 02:28 PM
curtisc19's Avatar
Yes you can. The backspacing is more for giving space for a wider tire. So no lift or lift, if you run a tire that is wider than stock (10.5"), you will need to adjust your backspacing accordingly.
Old Dec 7, 2011 | 07:17 PM
well the tires i have now are 10.5 i think...hmm...now you got me thinking, i'll have to look. i'm pretty sure they are 10.5 wide and i only rub a little when i turn real hard. but the dealer said that after i put the TF 3" lift on it i will need a wheel with 8 or 9 BS?!!!
