What Battery?
Old Mar 6, 2010 | 11:17 AM
mikegp's Avatar
Default What Battery?
What is a good battery and how many Cold Cranking Amperes do i need to operate a
Warn m8000 winch, and Piaa Fog Lights.
Old Mar 6, 2010 | 11:38 AM
slick willy's Avatar
Optima yellow or red top will do the job, be sure and put winch on top terminals. I burnt one up on side I found that out the hard way.
slick willy w4wtg
Old Mar 6, 2010 | 11:41 AM
mikegp's Avatar
will it short out the battery or burn the winch motor if its connected wrong?
mikegp's Avatar
oh and how strong should the battery be
Old Mar 6, 2010 | 02:45 PM
alancamby's Avatar
Warn recommends at least a 650 CCA for the M8000
Old Mar 6, 2010 | 03:10 PM
AZJeeper's Avatar
Community Favorite
Look at Odyssey batteries. I like them better than Optima. If you want to save a few bucks, look at the Sears Platinum battery - same as the Odyssey except with the Sears name.
Old Mar 6, 2010 | 03:26 PM
Stuka's Avatar
Excide also makes the Orbital battery which is the same design as the Optima, but for a much lower price. And ina winch test there wasnt much difference between them.
Old Mar 6, 2010 | 10:02 PM
mikegp's Avatar
ya both optima and orbital seem to be pretty decent. i checked out the test they ran on the orbital on rockcrawler.com.
those who have the dual battery, do your winches work better in any way.
it sounds like a stupid question but i assume dual battery gives less drainage on battery power than a single battery.
