what causes death wobble
Old Sep 22, 2011 | 04:31 AM
big c's Avatar
Default what causes death wobble
What causes it and how to fix it
Old Sep 22, 2011 | 04:37 AM
GreenJK07's Avatar
Many things. Could be trac bars, cam bolts, control arms and angles of driveshafts if you have adjustable CA's and they are not set correctly or tire balance. I would start at making sure all trac bar bolts are torqued to 125ft lbs and then move to CA's. Unbalanced tires can seem like DW if they are not balanced correctly.
Old Sep 22, 2011 | 04:41 AM
scotty6336's Avatar
RE CREATING THREADS CAUSES DEATH WOBBLE.
Find planmans writeup on it.
Old Sep 22, 2011 | 05:24 AM
Rubicon10's Avatar
Take your trackbar off and look at the bolt holes on the brackets to see if they are wallowed out. Most of the time this is the. cause. If that's the case then you need to reinforce them.
Old Sep 22, 2011 | 05:26 AM
Hskr4x4's Avatar
Fat girls cause it... Kick the fatty out, and you will be impressed how straight that sucker drives
Old Sep 22, 2011 | 05:28 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Click here --> Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles
Old Sep 22, 2011 | 07:24 AM
blw's Avatar
blw
More generically, death wobble can happen to any solid front axel vehicle (as opposed to independent front suspension). It's not just a Jeep thing.
Old Sep 22, 2011 | 07:28 AM
scotty6336's Avatar
Originally Posted by HappyCurmudgeon
x2. Thanks happy thats what I was referring too earlier, couldnt find the link...To the OP, this writeup is accurate enough to the point that I have a printed copy at home with some other jeep service manual crap. Read it.
Old Sep 22, 2011 | 07:42 AM
Turbo's Avatar
Mine started after a lift. After many changes the ball joints finally fixed it.
Old Sep 22, 2011 | 07:49 AM
SunnyD's Avatar
Damn! I was trying all the fixes and nothing worked. Kicked the heffer out and now it drives straight as an arrow!
