What could thump when hitting a pothole?
With what I have done to my JK ( see sig) basically OME kit, what could cause a thumping noise upon hitting a large pothole or such an obstacle? Could it be the normal shock noise? Any input would be appreciated.
The Bump stops are way away even at full flex so i don't think it is that. It could be the door latch , I will look at that
Hmm, interesting. i've experienced this exact same thing...going about 25 mph on the back road, and hit a large potholes. I've never really figure out what it was. BTW, i have RE 2" BB kit with shocks
Just my .02, Several treads here and other places about bad left front ujoints. I caused my axle flanges to break.
Lift the front off the groung by the frame and check it out. My only be the bump stop but why not be sure.
I would second this. Go over a bump that makes the noise and then turn around and go over the bump again but this time open your door a couple of inches if you don't here the sound then its the latch if you do hear it then its something else, you can try this with all the doors with the help of a friend. I had to adjust all four of my doors for the thud sound and now its perfect.
Assuming you have the spare on a bumper mounted carrier, could be coming from that.
