what diff cover sees more damage
Old May 26, 2015 | 05:08 PM
jeepmojo's Avatar
Default what diff cover sees more damage
front or rear it would seem like the front would in rocks but curious of what you find to be more prone to damage ?
Old May 26, 2015 | 05:16 PM
lowendrider's Avatar
I don't play in the rocks around here but for me its the front. I have noticeable scrapes on the front, not so much on the rear.
Old May 26, 2015 | 05:52 PM
orangedude71's Avatar
Rear is prone to peeling the edge while sliding over rocks. Front prone to dents. I used a riddler for the rear and a rugged ridge guard for the front
Old May 26, 2015 | 05:56 PM
tarpon4me's Avatar
JK-Forum Ambassador
I have had the same experience as orange dude. Two oil changes ago we found where the rear diff cover was push out slightly front rock contact. It had a very slight leak. Nothing a hammer didn't fix.
Old May 26, 2015 | 06:12 PM
jeepmojo's Avatar
Default ???
Do you risk loosing the seal when installing the guard having to remove several bolts up front? or not ?
Why did you choose to install a guard up front rather than a full cover ( seeing they are as much as some full covers ) ?
i was thinkin buying one at a time to protect them, im not sure if i should get the front or rear first lol prob should do both @ same time i guess to be on the safe side when doing so . I wasnt sure which one takes more hits over all.
Old May 26, 2015 | 06:47 PM
horrocks007's Avatar
An unprotected diff sees more damage.
Old May 26, 2015 | 07:15 PM
Originally Posted by jeepmojo
Do you risk loosing the seal when installing the guard having to remove several bolts up front? or not ? Why did you choose to install a guard up front rather than a full cover ( seeing they are as much as some full covers ) ? i was thinkin buying one at a time to protect them, im not sure if i should get the front or rear first lol prob should do both @ same time i guess to be on the safe side when doing so . I wasnt sure which one takes more hits over all.
I went with the guard because I was concerned about clearance issues with the trackbar or in the future if I was to install an aftermarket track bar. As I recall I did need to break the seal and refill. My rtv job was not the greatest and it leaked abit so I recently installed a lube locker. Problem solved
Old May 26, 2015 | 07:45 PM
jeepmojo's Avatar
Default ok yeh
my concern as well with monster track bar thanks
Old May 26, 2015 | 09:01 PM
Desert Crawler's Avatar
If you are playing in rocks I would go with the rear first. The lower lip can peel back leaving you with catastrophic failure if you are not prepared. I have seen this happen a few times. For what it is worth I have both on order.
Old May 26, 2015 | 09:07 PM
phuggit's Avatar
The rear cover.
