what to do??
Old Feb 18, 2010 | 02:11 PM
Default what to do??
ok so i have a 2007 2dr and i want to put 37s on it what do i need to do?
Old Feb 18, 2010 | 02:23 PM
ssunde1's Avatar
lots of different ways you could go about that, before someone yells at you, just check out the FAQ at the top of the modified JK tech page.
but to answer your question in short, you could get a 2.5-3" lift and cut the fenders, trim or fold the pinch seam in the rear, or you could get like a 4" lift without trimming i think would do it. but you will definately want to regear, depending on if you have an auto or standard prolly go with 5:13's either way, add some gussets to your axles if you wheel it, get a superchips, a rear tire carrier as a 37 will kill the tailgate otherwise.
thats a start
Old Feb 20, 2010 | 10:11 AM
would i need to get a new axle/axles or just gears??
Old Feb 20, 2010 | 11:23 AM
i dont do any rock crawling just trails mudding and driving to school. but thanks for the input
Old Feb 20, 2010 | 11:43 AM
JPSquad's Avatar
Don't forget front and rear drive shafts. All I need are fronts, and I could put my lift on. I have everything else.
Old Feb 22, 2010 | 02:00 PM
Default 40s on 2dr pics
ok how could i run 40s on 2dr??
pics would be great
Old Feb 22, 2010 | 06:32 PM
what exactly is trimming??
Old Feb 22, 2010 | 06:49 PM
JayhawkJeep's Avatar
Veteran: Navy
Take a look at the fenders in the picture. Those are the stock ones cut back.
Old Feb 23, 2010 | 12:04 PM
o ok so that is basically like a homemade flat flare. gotcha
Old Feb 23, 2010 | 12:09 PM
Veteran: Navy
Here is the write up.
http://project-jk.com/jeep-jk-write-...ry-fender-chop
