What to do????
Old Apr 27, 2013 | 06:08 PM
caryfire's Avatar
Default What to do????
I have 285/75/16 on stock rims with the Teraflex leveling kit so heres my question...... Should i get rims with 35s or keep my 33s and get a 3"lift. Will the leveling kit work with 35s. I will eventually get both but can only do one of the other first...... thanks
Old Apr 27, 2013 | 06:13 PM
k0260's Avatar
I'd go with the 3" lift for now. I started out with a 3" lift on 33's, worked great until I was able to go bigger.
old pic:Click image for larger version
Old Apr 27, 2013 | 06:17 PM
caryfire's Avatar
old pic:Attachment 451817
Thanks i guess i just needed to hear it from someone else.....Lol! Looking at the Teraflex or AEV!
Old Apr 27, 2013 | 07:17 PM
mcsjk's Avatar
AEV only does 3.5" kits... And personally I would go with Teraflex over AEV anyday of the week. They are similar in price but I think you will be happier in the long run with Teraflex... But thats just my 2 cents
Old Apr 27, 2013 | 07:37 PM
matprovo's Avatar
If you off road a lot I think TF would e your best bet. AEV use to make a 4.5" lift. Not sure if they still do or not. Lift first and then tires IMO
Old Apr 27, 2013 | 07:58 PM
stuozzy's Avatar
Ummmm....AEV for sure makes a 4.5 inch lift i installed installed on in feb of this year. I absolutely love it but it is my dd. with that being said i wheel every other weekend and have had no issues. If it is your dd I would say it is hands down the winner. If not look into the rock krawler kit both are complete setups unlike the teraflex.
Old Apr 29, 2013 | 03:46 AM
westchester's Avatar
Yes, you can run 35s on the stock suspension (no-lift) provided no heavy passengers, loads or off-roading. I went this route first, then installed a TF 2.5 coil lift - perfect lift for a daily driver on 35s - has been over 4yrs and no issues. So get the tires + rims first, then upgrad to a lift soon after.
Old Apr 29, 2013 | 04:49 AM
hooper's Avatar
Get the 35's and some flat fenders for now. Then save for a high quality 3" lift for later. The 35's will still look good with 3" lift and flats.
Also this is post 200 for me.
Old Apr 29, 2013 | 04:53 AM
mattyk's Avatar
Veteran: Navy
x2. i did the same. 3" bds which is a great lift and affordable. ran 33's for about a year. as soon as i ran into some money i regeared ffrom 3.21 to 4.56 and threw on 35's.
you will get more out of a lift long term then anything else.
Old Apr 29, 2013 | 09:30 AM
XTJake's Avatar
Former Vendor
Caryfire,
Do you need tires right now? If not, I say go for the lift kit and then start saving for a set of new tires. I'm the type of person who runs tires down past the wear bars. I get every last mile out of them!
If you're looking at a Teraflex or AEV lift, I say go Teraflex. If you plan on doing any wheeling with the Jeep, TF holds up better than AEV does off-road.
The Teraflex 3" Lift Kit comes with all the necessary brackets ans parts required to install it. The coils will ride great, even better than stock. Pair it with a good set of shocks, and I know you won't be disappointed with this kit.
Hope this helps! Let me know if you have any questions.
-Zach
