What To Do??
I hopefully will be installing a 4" lift this weekend. My weekend is Sunday/Monday. Weather permitting. I have a 4" lift from Rough Country and All 8 Currie Adjustable Control Arms. I have read WOL's write up's for the FT installation and the Currie installation. Currie has you set the length's of the control arms to factory specs and WOL has lengthening them. I am gonna use my stock 32" tires and 17" rims for now. (I wanna see what they look like with a 4" lift) (Credit card in hand if they look to bad). Anyway, should I use the factory lengths for the arms, see how it drives with the stocker wheels and tires or go ahead and lenghten them? Help is needed as Sunday Morn is the start date.
Thanks
Thanks
HAPPY 4TH OF JULY BY THE WAY.
MY HEART FELT THANKS GOES OUT TO ALL THE VETS AND THOSE SERVING NOW.
I DID 8 YRS. IN THE SERVICE FOR UNCLE SAM AND WOULD LIKE TO LET THOSE NOW SERVING KNOW THAT I APPRECIATE YOUR SERVICE.
What to do????
I'm not asking for opinions on tire and wheel size. I'm asking about what lengths to set my control arms. Later, when I get bigger tires I know this will change but in the mean time, should
I set them to stock measurements?
Or do I set them longer as in Eddies's write ups for the FT install??
Currie
Eddie
Someone Help.
I am gonn start this on Sunday Morning as Sun/Mon are my off days. I just want to get it close .
Thanks
On the RE 3.5 lift I just installed the lower arms are not adjustable but RE made them 1/4" longer than stock. I think that if you did the basic geometry you would find out that to maintain the stock wheelbase length you have to increase the length by about 1/4". You could take the stock arms, lower them 4" and measure the wheelbase and you would know what to do. Myself I would not go stock length but 1/4, 5/16 or 3/8 depending on what the lift actually turned out to be. My RE 3.5 ended up being an actual 3.5 in the back but 4 3/4" in the front. No more nose down!
