What to do ??? Gearing!
Old Feb 19, 2011 | 01:39 PM
jeepmojo's Avatar
Default What to do ??? Gearing!
Question i bought 2011 jeep sport has 225 /75 /16s on it
i want to put spacers and what ever the largest tire i can go with in a
to yo somthing like 295/70/17 0r 265/70 17 wich is 32 inch height and 10.8 wide on a rubicon wheel am i going to need to re gear this jeep ?? Is it going to strain my tranny ? I thoght these things were made for this stuff geeeees im into regearing just to add a 32 inch tire ??? If so what gear size and cost roughly having some one do it ! To a 4.10 and do they re gear front and rear?? Im new at this jeep stuff thanks in advance!
Old Feb 19, 2011 | 01:40 PM
Pluke the 2's Avatar
spell check
Old Feb 19, 2011 | 02:09 PM
nthinuf's Avatar
Get the new tires and then decide if you need gears.
If you do re-gear, Yes, you need to do both axles. (unless you want to pull the front driveshaft and be permanent 2wd)
Prices vary by location, expect somewhere between $1000 and $1800. That is all parts + labor for both axles. East coast is generally higher, so plan on the upper end of that range.
Also, if you have not found the Faqs yet, they are stickied to the top of this modified area. There is a good Drivetrain area with some good gearing and RPM info
Old Feb 19, 2011 | 02:16 PM
GREENJEEP80's Avatar
I am getting ready to re-gear mine and I am looking at about 2K. It is worth it.
Old Feb 19, 2011 | 02:40 PM
I got my 5.13s from dave at northridge. He gave me a great deal on the package....lol and my cost of labor to have them put in was a case of beer, which after 9hr of the install went pretty fast
Old Feb 19, 2011 | 02:47 PM
bailey1575's Avatar
just installed usa standard 4.56s front and rear cost me around 9 thru randys but that was at wholesale then took one day off work and did em my self well see how they sound just finished lift i hear northridge is the place to go wish i would have done more research and supported our jk community. find out what axles and gears
you have if the sport is with tow pak the 3.73 might be in there and thats not far from410 other wise 321s and then yep would recommend new gears i had 265 70 m17 toyos and they were on when bought jeep with 5000 hate them just bought 35 km2s and there b a
Old Feb 19, 2011 | 03:11 PM
rider81's Avatar
im thinking about regearing also. a buddy of mine had his regeared and installed for around 1200. i think thats what he said anyway.
Old Feb 19, 2011 | 03:29 PM
jeepmojo's Avatar
Default now im wonderin wha i bought this for if it cant even hold 32 inch tires grrrrrr
so im lookin at like 2000 for gearing and 2000 granf for tires and 2000 grand for wheels and 23000 for jeep maybe ill leave it stock what size tire can i put on without regearing that would look better than 225 75 16 that are on there , ill have to think about trading inin a year or two for rubicon ! i thought a new jeep would be fun! but after seeing how much money goes into it just to go destroy it , im gona think stock and just mall crawl
Old Feb 19, 2011 | 03:36 PM
u-joint's Avatar
Just for a point of reference...
I did my wheels AND tires, and together I spent less than $2K, and I'm running 35s.
As far as gears go, my gears (parts & labor) was $1,600.
Just a little FYI that things might not be as expensive as your fearing they are. Hit up our vendors, they can work out awesome deals for you and help you save some $$$
Old Feb 19, 2011 | 03:49 PM
JEP THNG's Avatar
I did 5 tires (35's) and 5 wheels for under 2k. Gears r $550....u just need a hookup on the install.
