What do I need to run 40 inch tires.
Old Feb 15, 2012 | 08:37 PM
jkcraze's Avatar
Default What do I need to run 40 inch tires.
I am looking to get some 40 inch Toyos, what do I need to run them.
Old Feb 15, 2012 | 08:39 PM
FoxRacingJMC's Avatar
Deep pocket$$$$$$$
Old Feb 15, 2012 | 08:50 PM
JKJon's Avatar
Start with 40 Inch Toyos
Old Feb 15, 2012 | 08:53 PM
jaker t5's Avatar
What setup you have right now , if you are close not much but if you bone stock well a long way to go
Supro's Avatar
x2
Old Feb 15, 2012 | 08:58 PM
medic_23387's Avatar
If you don't have at least a Dana 44 in the front don't even try it. I would personaly want front and rear Dana 60 axles. You need to sleeve and gusset your axles. You will have to have a lift to accommodate, regear to at least 5.13. Probably a 20 inch rim. New heavy duty ball joints and steering components. To do it safely were ur not breaking something every two seconds. Prob a lot more I'm missing but I'm sure someone will give u the full exact set up u need
Old Feb 15, 2012 | 09:09 PM
Lancejk's Avatar
Just run it, see what breaks and replace. You probably won't have any problems until you try to wheel it hard. IMHO I don't think you need as much As would be let on, I've have plenty of 4x4s all over 40" tires, the jeep being the smallest and have ran everything from 30s to 60 axles and only have problems ever in the mud on 44s and a Dana 44 front locked under the power of a 383 stroker. Good luck and as I said be prepared to break some thing and run it and repair it.
Old Feb 15, 2012 | 09:15 PM
Prob wouldn't go that route. You can have some major failures that cost a lot to fix if your not set up for it. Not to mention leaving u stranded on a trail. What if he is running 3.21 gears I'm sure he would like topping out at 40mph and it taking him a year to make it there. We need more info on ur current set up like what axles u have and current gears ur running
Old Feb 15, 2012 | 09:17 PM
Lancejk's Avatar
Don't let people scare you with extreme situations. Take it easy and monitor your jeep and it will be fine.
Old Feb 15, 2012 | 09:34 PM
wayoflife's Avatar
JK-Forum Founder
depends on if or how you plan on wheeling your jeep.
