what is a draglink????
Old Sep 11, 2010 | 02:24 PM
zjk's Avatar
zjk
Default what is a draglink????
what is a draglink ?& how do I adjust it?, IM puting on a 21/2" lift kit
Old Sep 11, 2010 | 02:26 PM
wayoflife's Avatar
JK-Forum Founder
this should help you out...
to adjust it, simply take a 15mm wrench, loosen up the bolts on the turn buckles and then rotate it. if you need your steering wheel to go to the left, rotate the turn buckle up and vise versa.
Old Sep 11, 2010 | 03:02 PM
JEP THNG's Avatar
have a pipe wrench handy to rotate it and it is a piece of cake
Old Sep 11, 2010 | 03:08 PM
southbaydog's Avatar
Instead of a "pipe wrench" hit the threads with WD-40 use a lot of it until it breaks free.
It will break free just be patient
Once you get the rust out of the threads it will turn easily.
You don't want to strip the threads on a tie rod which is the risk you take using a "pipe wrench".
Tie rods are EXPENSIVE.
A "pipe wrench" is for pipe, not a tie rod.
Old Sep 11, 2010 | 07:15 PM
zjk's Avatar
zjk
thanks guys
