What else do I need
I recently bought 35''s and Teraflex 2.5 coil lift with shock extensions. Neither are installed yet. I plan to gusset my c's soon.
What else do I need to add to my suspension to keep from breaking anything or to improve ride and all that? I dont know much about much so any help is appriciated. Also if you could include a time frame of when I should do this. For example the gussets can wait awhile more than likely.
Thanks.
Thanks.
Thanks.
Thanks.
Teraflex 1352000 - TeraFlex 2.5" Lift Kit with Shock Adapters for 07-12 Jeep® Wrangler Unlimited JK 4 Door - Quadratec
Im not sure but thats the link to the lift.
Lockers, steering stabilizer upgrade and relocation bracket, Sleeves, Rock gaurd diff covers, steel brake lines, 30 spline axels( for Dana 30), Evap relocation or skid plate, beadlocks. The sky is the limit.
What kind of wheeling, and how often? How hard do you plan to push your Jeep?
For example adjustable LCA's ect.
bump stops, brake line extenders on back, longer rear swaybar link, rear track bar bracket. you get all that with it?
Bump stops yes, brake line brackets are included, I assume this is the same as extenders. Rear sway bar links are inlcuded, I assume this to mean they are longer, Track bar bracket is inlcuded.
So yes, sounds like im g2g. Thanks for the info!
