what else for lift?
Old Feb 23, 2010 | 09:22 PM
sktdarkstar8's Avatar
Default what else for lift?
i have a tf 2.5in lift and i am looking at getting the TF 1in spacers for front and rear... i assume this will bring the lift to about 3.5inches give or take.. i have the coil and shock lift with adj trac bars, control arms, and the minor parts that came with the lift kit..
is there anything else i will need? brake lines, rear upper bump stops, front lower bump stops, sway links or anything along those lines? thanks
Old Feb 23, 2010 | 09:28 PM
wayoflife's Avatar
JK-Forum Founder
i would definitely consider long brake lines. if you don't already have bump stop extensions (i would imagine you would), i'd pick up a set. longer links or adjustable ones is a good idea as well. being that you have a 6-speed and an unlimited, you'll be fine with the factory driveshafts. otherwise, it sounds like you're in good shape.
