What Front Spacer to Level??
Old Feb 7, 2013 | 08:39 AM
tvan93's Avatar
Default What Front Spacer to Level??
Ok, so I just added a bumper and winch, and now my front end is sagging a bit too much for my liking. I was was wondering what size spacer I could put on top of the spring to get rid of the sag. Also, my problem is that I am not sure how a spacer would work because I already have a 2" budget boost, so there is already a spacer under the spring. Anyone done something like this? I need some ideas on how to fix this.
Thanks
Old Feb 7, 2013 | 09:03 AM
Ryan0260's Avatar
How much did it sag? The best solution would be to go with a longer coil
Old Feb 7, 2013 | 09:11 AM
Jersey_Devil's Avatar
Don't stack spacers.... Get a set of 2.5 coils and then add a 3/4"-1" spacer
BUT DONT EVER STACK SPACERS!
**Edit**Just saw this on the forum
https://www.jk-forum.com/forums/spon...hipped-252915/
Old Feb 7, 2013 | 02:30 PM
BKGM Jeepers's Avatar
Like mentioned above, I'd just look for a used set of 2.5" lift springs for the front and throw them on. Further, I'm a huge fan of adjustable coil over spacers and ran them on every one of my jeeps until I went coilover up front. The adjustable spacers solve problems like you are facing which is every time you do a mod you need to buy or change things. ACOS can be adjusted in short time to correct droop by simply extending them...
