What gears do I have?
Old May 28, 2011 | 07:04 AM
davyjones616's Avatar
Default What gears do I have?
I have a 2010 basic sport two door. I threw away the spec sheet that was on the window when I bought it and now Im wondering what gearing I have since I want to upgrade my tires to 35's. I am currently running bighorn maxxis 265/ 75/ 16's up from the stock 29 inch tires with no problems, but now with the BB, HD coils and chopped fenders the tires look a little small.
Ive looked at the gearing chart and if I have the 3.21 gears it doesnt look good at all for 35's, if i have the 3.73 gears it looks like it will most likely be bearable for awhile until I can afford to upgrade....
Any thoughts or ideas?
Thanks!
Old May 28, 2011 | 07:12 AM
IcyFridge's Avatar
Best bet is to give your VIN to a dealer and they can look that up for you in a snap.
If you are a secondhand owner, then you need to jack up the jeep and count how many times the driveshaft spins. I am not sure on the numbers, but people will chime in.
And I have been talking with people with 3.21s and a manual and they say 35s are not too bad for a while. I plan on going to 35s with my 3.21s for a bit.
3.21's on a 6 speed is slightly better than 4.10s on an auto according to the gearing chart in the FAQs. You should be fine for city driving, but highway might be a pain. If you have a 6 speed, just drop it to 5th or 4th and you can deal with it.
Old May 28, 2011 | 07:31 AM
NMJeeper's Avatar
Jack up the rear end, rotate tires and count the driveshaft rotation. quicker than driving to the dealership, ~ 5 minutes.
Old May 28, 2011 | 09:53 AM
nthinuf's Avatar
Try the VIN decoder in the Research area here:
hxxp://www.compnine.com/index.php
If your jk is in the system, it will show your build sheet.
Old May 29, 2011 | 10:51 AM
aermotor's Avatar
Do you have a towing package and a 44 rear axel? If so you're most likely running 4.10s – another quick way is to use this chart.
