What gears for my JK? Worth doing?
Old May 2, 2009 | 09:39 PM
kurtfriedrich's Avatar
Default What gears for my JK? Worth doing?
I have an 08 JK Sahara 2 door, stock engine, fair amount of weight with armor, winch, hardtop. 33" tires. I am not going to go to 35s, so I want to pick the best ratio for my 33s.
Stock gears are 3.73 with manual tranny.
I want lower ratios for offroad. With 4.46 1st gear x 2.72 xfer case:
3.73 dif = 45.25 Crawl Ratio (2000 rpms = 4.4 mph)
4.11 dif = 49.86 Crawl Ratio (2000 rpms = 4.0 mph)
4.56 dif = 55.32 Crawl Ratio (2000 rpms = 3.6 mph)
4.88 dif = 59.20 Crawl Ratio (2000 rpms = 3.4 mph)
(Rubicon Crawl Ratio is 73.1)
So for sure I want 4.88's
But, I also don't want to be blowing the front D30, and I don't like how as you gear lower, the pinion gets fewer and fewer teeth:
3.73 41 and 11
4.11 41 and 10
4.56 41 and 9
4.88 39 and 8
I sure don't like going down to 8 teeth.
now the more I look at this, the less clear it is I should even change the gears.
I would be:
* spending a bunch of money
* going from 11 to 8 teeth
* and at 2000 rpm the diff is only 3.4 mph verus 4.4
Is it really worth regearing?
Should I go with the 4.88 and weaker 8 teeth or 4.56 and 9?
How much will this cost me?
Old May 2, 2009 | 10:00 PM
w.wood jeepster's Avatar
save up for an atlas if you want to lower the crawl ratio and don't plan on going to 35's.
Old May 3, 2009 | 02:51 AM
JPop's Avatar
I tend to agree with the Atlas suggestion. The path that you have taken with your Jeep and how you use it make what a third party transfer case brings more appealing than the path so many others take with somewhat larger tires and most of all having a 6 speed as opposed to an automatic.
For me I'm just not that interested in throwing any money at a D30 and when it breaks I'll move to D60s, different gears and move the vehicle to the third position of what my wife and I will use for normal on road tasks.
Old May 3, 2009 | 03:00 AM
RedneckJeep's Avatar
Nope, it ain't worth regearing. Least from what all I've read on here. Spend it on sumthin else. More nitrous.
