What is needed to run 35" tires??
Old Mar 31, 2008 | 08:28 PM
JeepJK4Life's Avatar
Default What is needed to run 35" tires??
i know u need regearing but how much? and how much would it cost me?
Old Mar 31, 2008 | 08:38 PM
o yea and has anyone ran u.s. steel wheels? and how do they look and run?
Old Mar 31, 2008 | 09:00 PM
scouter4life's Avatar
Re-gearing will certainly help, but if you have 4.10's you should be fine for a while if cost is an issue. If cost is not an issue, then re-gear to 4.88's or 5.13's. I'm assuming you already have a lift, if not, expect rubbing. Dont forget to get your spedometer recalibrated also.
Can't help you on the wheels.
Old Mar 31, 2008 | 09:02 PM
SH0RTBUS's Avatar
If you have a manual transmission, regearing isn't necessary. I probably isn't even necessary with an auto, but it will make driving easier and more fuel efficient. I can't comment on the wheels.
i dont have a lift yet but i plan on running the 2.5TF lift do i need wheel spacers? and what kinda rim specs should i look for?
Old Mar 31, 2008 | 09:18 PM
alright scrap that idea
