What is this noise?
Old Mar 18, 2018 | 05:46 PM
John2010JK's Avatar
Default What is this noise?
Let's play 'Name That Tune' (or noise). I need some help identifying this noise. It not always present, but occurs when I press the gas. Sometimes it's softer, sometimes louder. In the video, when it stops, it's because I let off the gas. What do you think?
Old Mar 18, 2018 | 06:04 PM
Mr.T's Avatar
Community Favorite
I'll play! -- Heat shield, exhaust crossover near the cross-member. Look carefully for a broken tack weld, pry lightly with a screwdriver. Had to re-weld a couple on mine.
Old Mar 18, 2018 | 07:19 PM
Wandell's Avatar
Loved
I agree. Try putting a couple of gear drive hose clamps around that heat shield.
Old Mar 19, 2018 | 05:07 AM
John2010JK's Avatar
Ok - thank you, gentlemen!
Old Mar 20, 2018 | 11:49 AM
Mr.T's Avatar
Community Favorite
Have you checked, was that it?
Old Mar 24, 2018 | 07:39 PM
John2010JK's Avatar
It looked OK to me. A shop checked the heat shield and said it wasn't loose. Another couple of people thought it was wheel bearings. Those were replaced, but the noise is still there. Tuesday they'll replace the pinion bearings. I'll let you know how it goes!
Old Mar 28, 2018 | 06:37 PM
John2010JK's Avatar
Well, when the shop went to replace the pinion bearings, they saw that the pinion gear was missing a chunk out of it. So, that is likely where the noise is coming from. The gears will be replaced early next week. I hope to have a picture or two.
Old Mar 28, 2018 | 06:56 PM
Mr.T's Avatar
Community Favorite
Sometimes a chunk can get whipped up in the oil, get caught in the gears, and it feels and sounds like the car ran over a 55 gallon drum. Were these the OEM gears or replacement gears that failed?
Old Apr 1, 2018 | 05:34 PM
John2010JK's Avatar
They are Yukon 5.13 gears.
