What order?
Old May 22, 2008 | 09:05 AM
soundone's Avatar
Default What is the proper build order?
With all these great mods and products, I haven't seen any mention to build order.
When building a new 4-Door JK, what do you do first?
My plans are:
4" Suspension Lift
37" Wheels and Tires
Steering Assist
5.13 Gears
Front and Rear Bumpers
Winch
Headers and Exhaust
Bigger Brakes - (Any suggestions?)
Aux Lighting
While some may seem more obvious than others, I would think that the suspension
sould be done after the bumpers and winch be cause of the weight.
(But it's the thinking that usually gets me in trouble.)
Old May 22, 2008 | 09:39 AM
whatroads's Avatar
1) Rock Rails
2) Evap relocation
3) Oil pan skid
4) Go wheeling
Old May 22, 2008 | 10:26 AM
soundone's Avatar
Default Evap
Originally Posted by whatroads
1) Rock Rails
2) Evap relocation
3) Oil pan skid
4) Go wheeling
Evap relocate? Why? & Where?
Old May 22, 2008 | 11:38 AM
mongo's Avatar
1. LIFT
2. RELOCATE- evap canister, steering stabilizer
3. PROTECT-rocksliders, skidplates
that seems like the most important steps to me...atleast it was to me after wheeling hard for the first time
Old May 23, 2008 | 11:37 AM
whatroads's Avatar
Relocate your evap cannister or loose it on your first outing. Look under your Jeep. Passenger side, about mid-way back and you'll see it mounted in harms way. Do a search and you'll find plenty of information on relocating the evaporation cannister
Old May 23, 2008 | 12:25 PM
muddpuppy01's Avatar
only brake upgrade that I know of requires you to run 20"+ wheels
Old May 23, 2008 | 12:42 PM
BaltChief's Avatar
I would think you should look at what you want to do with your Jeep.
Do you want to offroad?
If yes in rocks then go for protection first...
If yes in woods, sand, mud....then get your winch first
If no offroading till you are done then get lift and tires first..
Old May 23, 2008 | 06:15 PM
JK Dawg's Avatar
Relocate your evap cannister ... Passenger side, about mid-way back and you'll see it mounted in harms way.
Uh oh! Then what's that black plastic box on my driver's side?
Old May 24, 2008 | 06:42 AM
dpoelstra's Avatar
That is a bit of an overstatement. Many wheelers havenot relocated the canister (me included) and I have beat the heck out of my undercarriage with no problems. I am going to relocate it, but it definately would not be the first thing I do.
If you are not running a Rubicon, and you intend to seriously wheel, lockers are in order, along with a lift tires, rock rails and a high lift jack. Then I would look at a belly skid plate so you don't crush your oil pan and exhaust pipe ( a more likely point of damage then the evap canister).
This set up will get you a tone of wheeling with no problems. The rest is noce to have and just makes it better...things like a CB, bumpers, winch, lights...the list never ends.
Have fun.
Old May 24, 2008 | 12:29 PM
riverzendz's Avatar
There are skid plates for the evap canister if you do not want to relocate.
