What is this plug?!
Old Jul 30, 2009 | 10:00 AM
rcdude3's Avatar
Default What is this plug?!
I just picked up a dana 44 front from deanthemachine04 and i know this came on here from the factory, but what if this other plug?
Old Jul 30, 2009 | 10:39 AM
Torch's Avatar
Right off hand I'd say it the speed sensor. sorry thats wrong.
The top plug activates the locker. The bottom is the locker indicator
Old Jul 30, 2009 | 10:49 AM
ronjenx's Avatar
Not a speed sensor. Speed data comes from the left front ABS sensor.
The top connector in the picture is the locker power, the bottom one is the locker position sensor.
Old Jul 30, 2009 | 10:50 AM
rcdude3's Avatar
it cant be that cause my front 30 doesnt have it. Daveid at NR4x4 said is is a locker plug. I just looked at my rear with the factory locker and it has the same thing...
Old Jul 30, 2009 | 10:51 AM
rcdude3's Avatar
so how could i make a custom wiring harness?
Old Jul 30, 2009 | 10:58 AM
ronjenx's Avatar
I take it you are adding locker axles, front and back?
If so, you have a huge advantage, in that you don't have to bypass or fool the computer. Wire it up like a set of aux lights; switch, relay, wiring, etc. You can even include the sensor to illuminate an indicator light, or the switch when locked.
You can select either axle, anytime you want. Just don't lock on the road at road speed, as that would be the quickest way to disaster.
Old Jul 30, 2009 | 11:04 AM
rcdude3's Avatar
Well my X came with the rear factory locker. I have the daystar lower switch panel so i was gonna just wire it to that.
so wire it like this? then throw in a switch? well also hook it up to the battery.
Old Jul 30, 2009 | 11:09 AM
ronjenx's Avatar
No. Nothing like that.
If your JK came with a rear locker, then the wiring is all set.
The front axle will be simple to wire like a set of lights. Like I said, switch, relay, wires, etc., to the power plug only. You can skip the sensor wiring, or wire it separately to provide a ground for a light.
Old Jul 30, 2009 | 11:13 AM
rcdude3's Avatar
ok...
Old Jul 30, 2009 | 11:55 AM
RedneckJeep's Avatar
That's for the flux capacitor.
