What PSI for 33" KM2's?
Old Oct 17, 2008 | 07:12 PM
REL1203's Avatar
Default What PSI for 33" KM2's?
I just got my KM2 285/70/17 installed on my AEV Pintlers, and am not sure what PSI i should run them at. I think Costco filled the tires with nitrogen to 30 in the front, 35 in the back, but not sure what most people run them at?
Also, from 0-7mph, it seems like its a little rough (kinda hard to describe the feeling), but once you get past about 7mph, things seem fine. I have never driven a M/T tire before, so I dont know if this is normal or not, but thought I would ask. Could it just be the new tire getting used to being on pavement?
Old Oct 17, 2008 | 07:25 PM
Robar's Avatar
Don't worry about the roughness from 0-7. The lugs on the KM2s are fairly large and that is what you are feeling. It will smooth out a little after a little wear.
As far as the air pressure you should probably run an equal amount of air in all of the tires.
Try using the chalk test to determine you air pressure.
Get a piece of sidewalk chalk and a tire pressure gauge.
Draw a chalk line across the entire tread of all 4 tires, wide enough to see good. Drive in a straight line for about 100' or so then look at the chalk.
You are shooting to get the chalk to wear evenly across the entire tread pattern. If the chalk is worn on the center you have to much pressure and if it is worn on the sides you don't have enough air. Do this (removing or adding air pressure) until you find the pressure that wears the chalk line evenly. This will give you a good ride, even tire wear, and the best foot print.
Old Oct 17, 2008 | 07:29 PM
Frog Rubicon's Avatar
I have the KM2 33" tires (255 80 R17)
On road: 35 psi
Off-road (mud): 25 psi
Off-roaf (rocks): 20 psi
Old Oct 18, 2008 | 04:47 AM
I am running 35 for my DD and I drop it to somewhere around 12 offroad.
Old Oct 18, 2008 | 05:44 AM
kb7our's Avatar
28 PSI front & rear on a 4800 lb Jeep daily driver and tires are wearing extremely well.
Old Oct 20, 2008 | 07:00 AM
REL1203's Avatar
so i dropped the PSI to 31psi in all 4 tires, but this morning, my TPMS light came on and stayed on the entire ride to work. I was VERY cold this morning, like 35 degrees according to the temp gauge on the jeep. Is there something that i can get done to fix the TPMS sensors?
Old Aug 9, 2009 | 06:25 AM
LIVEABOARD's Avatar
Who else is using this size E rated KM2 tire on JK would like to hear opinions worried about to stiff heavy what do u think ?
