what rear bumper and keep.......
Old Oct 9, 2013 | 06:54 PM
bludevlsi's Avatar
Default what rear bumper and keep.......
The factory hitch.
What your suggestions?
Old Oct 9, 2013 | 07:25 PM
karls's Avatar
GenRight rear- it's tight up on the body and comes in alum or steel with or without reverse lights, also has d-ring mounts for recovery. It bolts into a ton of spots for extra reinforcement.
My aluminum (pictured and since re-painted with satin black) weighs in at 20lbs- that includes the 2 slugs they supply you with for d-ring mounts.
Sent from my DROID4 using Tapatalk 4
Old Oct 10, 2013 | 05:03 PM
8052949's Avatar
Originally Posted by karls
GenRight rear- it's tight up on the body and comes in alum or steel with or without reverse lights, also has d-ring mounts for recovery. It bolts into a ton of spots for extra reinforcement. My aluminum (pictured and since re-painted with satin black) weighs in at 20lbs- that includes the 2 slugs they supply you with for d-ring mounts. Sent from my DROID4 using Tapatalk 4
How easy was the install on it?
Old Oct 10, 2013 | 05:25 PM
karls's Avatar
There are a bunch of places that it is secured but it wasn't too bad at all. It's much easier with the low weight of it.
Old Oct 10, 2013 | 05:28 PM
Rutgyr's Avatar
The Ace Engineering Pro one doesn't retain factory hitch but does include one.
