What should I do first
You might consider new wheels with better backspacing (4.5" or less), or else spacers if you plan to keep stock wheels. Right now I'm running 4.5" BS wheels and a 2.5" BB with 33s and have mild rubbing on very tough terrain.
as mentioned, you'll want to get wheel spacers or new wheels with less back spacing to prevent any rubbing with the new tires. if you go 35's, you may find it necessary to install a 1" body lift as well. aside from that, a lot of what you may need will depend on the kit that you get as some come more complete than others.
How soon you will need to the gear upgrade depends on your expectations for performance. There is one active thread regarding 3.21 gears, where several JK owners are merrily putting around (and I use the term loosely
) on 3.21s with 32-33s and plan on doing so forever. There are others like myself that find the 3.73s with these tires barely tolerable.
