what should I know
Old Apr 4, 2011 | 10:19 AM
Shop Teacher's Avatar
Default what should I know
I have decided to trade my 08 jk unlimited in. It is an automatic with 2.5 budget boost and 33' s . I want a wrangler 2 door with a manual trans. What are the most recent options that I should get.. what models come with the bigger gears? Will I be at a huge disadvantage if I get the sport ?
Old Apr 4, 2011 | 10:27 AM
mike-d's Avatar
This is simple. One word RUBICON!!!
Old Apr 4, 2011 | 10:56 AM
Blakspire's Avatar
Rubicon:
1.) E-disconnect sway bar
2.) Lockers
3.) 4.10's
4.) 4:1 Transfer case (For an overall crawl ratio of 75:1)
5.) Dana 44 front axle
6.) 32 Spline dana 44 rear
Sport:
1.) Solid sway bar
2.) Open diffs
3.) Dana 30 front axle
4.) 30 spline rear 44
5.) 2.71:1 low range (I think)
6.) 3:73's (I think)
The rubicon is the way to go. If you add up the cost to upgrade the components in the aftermarket form, it will cost you more.
2 cents
Old Apr 4, 2011 | 11:31 AM
jeep2007's Avatar
The money you save by getting a Sport can do a lot of mods. Rubicon or not, you go 35 or bigger tires, you'll regear it anyways eventually. Good luck to you!
