What size spacers?
I just purchased some AEV Pintler beadlocks. They are backspaced at 4.7" I believe. If I wanted to run 37x12.5 or 37x13.5 tires, what size of wheel spacers would I want to go with? This would be coupled with a TeraFlex 4" Long arm.
Well Teraflex recommends a minimum of 4.5" backspacing. I am worried that if I stay with the 4.7" and air down I will rub? Especially if I go with the 13.5 wide tires. Am I correct in that it will rub without spacers? Are the teraflex spacers hub centric also?
I'm currently running Pintlers w/Goodyear 37x12.5 MTR Kevlars. I do not need spacers. I did have to adjust my steering stops.
I had Toyo 37x13.5 MT Open Countrys on for 1500 miles. With the Clayton adjustable rear upper control arms, 1 1/2" spidertrax spacers were necessary. Also the Toyo's stuck out about 3" past the fenders causing alot of crap up the side of the Jeep.
I wish I would have asked someone before buying the Toyo's ..... Quality tire (no question), but imho just not the right tire for a JK. Too heavy, too stiff (load range e).
**Edit: THe factory rim with a 1.5" spacer puts the centerline of the tire at a 10mm offset. Same as a 9" rim with just under 5" backspacing.
