what size winch
what size winch would be recommended for the 4 door jk with 37x13.50 tires. few of my jeep buddies say the 9.5 is not enough and to go with the 12,000. any recomendations from the 4 door owners?
Someone correct me if I'm wrong here.
I believe you are supposed to go with at least 3/4 of the weight of your vehicle. I think the 9.5 should work fine. Not only that, but if you use a snatch block you are essentially doubling your winches power. (But the line speed will be cut in half)
Good luck in your quest for a winch.
I believe you are supposed to go with at least 3/4 of the weight of your vehicle. I think the 9.5 should work fine. Not only that, but if you use a snatch block you are essentially doubling your winches power. (But the line speed will be cut in half)Good luck in your quest for a winch.
thanks, i guess i'll just stick with 9.5, a 12,000lb and plate are made that will fit the jk. thats also why i was curious what size to get seeing that the bigger one is made for it. appreciate the responses.
And the latest issue of Off-Road Adventures shows the new Warn Endurance 12.0 mounted on a Warn bumper on a JK. But, that could be just advertising fluff. However, I don't mean to suggest that anyone needs a 12K winch; people smarter than me say otherwise.
