What are the true tire widths for 35x12.5?
Old Dec 15, 2008 | 05:42 PM
superman_tom's Avatar
Default What are the true tire widths for 35x12.5?
I've been looking around at tires and trying to decide what MT's to go with and I've noticed that there is a difference between the brands that are noted at 12.5" wide...
Toyo for example is just over 13", where the KM2s are listed at exactly 12.5"...does anyone know any others??
Old Dec 15, 2008 | 07:13 PM
2climbbig's Avatar
typically the tread is around 10 inches in width
Old Dec 15, 2008 | 07:16 PM
X2. You'll really want to see and measure the tire is tread width is a concern. Hardly any tires are the stated width at the tread. It can be very confusing at times, especially when trying to mate a wheel with the tire.
Old Dec 15, 2008 | 07:20 PM
JulietKilo's Avatar
12.5 is the width of the buldging sidewall aka section width.
Acutal tread width has to be measured after tire has been mounted. Manufactures dont even list the width from what I found on tirerack.
Old Dec 17, 2008 | 03:00 AM
HappyCurmudgeon's Avatar
Eternal ***erator
It depends largely on the width of the rim you are installing them on as well. Most mfg. will list a width on a certain rim width, change that, you'll change the measurement as well.
Old Dec 17, 2008 | 05:27 AM
jeepguyinMS's Avatar
Tirerack has a really good chart for each brand/model of tire that shows different size tires and what thier actual measurements are including the width of the rim they measured it on.
Old Dec 17, 2008 | 05:36 AM
wayoflife's Avatar
JK-Forum Founder
just so you know, even what is listed on a website as an actual dimension is in reality rarely accurate. every make is different and most tend to be smaller than what is listed.
