What type of grease for trackbar?
Old Sep 17, 2011 | 09:46 AM
Trauma's Avatar
Default What type of grease for trackbar?
I have the rock krawler front adjustable trackbar, its been making extreme creaking noises like its gonna fall apart. Nothing at highway speeds but in the neighborhoods its horrible.
I know for a fact its the track bar, ive spent a couple hours isolating the sound to be certain.
I called them up, they said this is like unheard of, i have retorqued everything (with weight on the axles) and all that. No death wobble to speak of.
Im gonna try pumping a ton of grease on either end. What should I use?
Old Sep 17, 2011 | 09:56 AM
mkjeep's Avatar
Um, I use Lucas red & tacky on my stuff, no creaky issues. I don't have an RK bar though. I have a TF, but use the red and tacky on everything.
Old Sep 17, 2011 | 09:58 AM
sa29560's Avatar
My adj track bar does the same, not sure if i should rebuild the joint if it is serviceable. Mine is also three years old so that makes a little sense. I grease at every oil change with a general grease but it is also red in color. . . picked it up at pep boys.
And if it is all torqued down its worth a shot
Old Sep 17, 2011 | 01:57 PM
dinojeep's Avatar
Good to know, Ill be installing my RK 5.5in lift with 3.5in coils next week!
Old Sep 17, 2011 | 02:58 PM
jeeeep's Avatar
x2 on Lucas red
Old Sep 20, 2011 | 08:13 AM
Trauma's Avatar
So pep boys by me only had lithium grease which I bought
I covered the ends in the stuff and after a few hours im right back to where I was noise wise.
Should I remove the lithium grease and try and acquire lucus red?
Whats the best way to get all the grease off lol.
Old Sep 20, 2011 | 09:32 AM
Biggy's Avatar
No noise from my RK stuff. I spray the ends with Fluid Film. I thought they didnt recommend using grease but to use something lighter like 3&1 oil
Old Sep 20, 2011 | 10:07 AM
Trauma's Avatar
Well Ive tried WD40 and silicone spray with no resolve either.
It sounds like a horrible creaking/stretching noise im 99% certain its the trackbar. Which is only 6 months old.
I guess il wipe the grease off and call them again...
Old Sep 20, 2011 | 10:09 AM
Biggy's Avatar
The locking nut for adjusting is tight as well
Old Sep 20, 2011 | 10:18 AM
Trauma's Avatar
Yep... Idk if I could possibly make it tighter il try...
