what wheel bs
Old Sep 1, 2011 | 08:52 PM
zero3's Avatar
Default what wheel bs
Going to order the rock krawler 5.5 X FACTOR COIL OVER LONG ARM SYSTEM for my jku. i was just wondering what back spacing i should run? is 4.5 enough or should i be looking for a lower/higher number? i am gonna be running 37's if that matters. thanks guys
Old Sep 1, 2011 | 09:08 PM
fish's Avatar
From: Apple Valley, California Good ole Mojave Desert.
this link is from the sticky at the top of this page. lots of good info in here about BS among other things.hope that helps
https://www.jk-forum.com/forums/show...ery-Newbie-Has
Old Sep 2, 2011 | 07:17 PM
zero3's Avatar
thanks fish. i had already read the sticky. it was a range of numbers i was just seeing if there was a specific recommended number for that lift in particular. they are gonna be km2's if that makes a difference. 37x13.5x17
Old Sep 2, 2011 | 07:37 PM
nthinuf's Avatar
If you aren't hobbled by fender coverage laws, I would go with less backspacing. 4.0" or 3.5".
But a lot depends on the 'actual' height and width. 37's that turn out to be 35" x 12" will have different backspacing needs than 37's that are 37" x 14" when sitting under your jeep.
Old Sep 2, 2011 | 08:32 PM
Wandell's Avatar
Loved
I think a 9 inch wide wheel with 4.5 inches of BS is perfect for a JK.
Old Sep 3, 2011 | 08:11 PM
zero3's Avatar
thanks for the help guys.
Old Sep 3, 2011 | 08:52 PM
dmick33's Avatar
Is there a 15x8 rim with 4 inch backspace that will work without rubbing on the caliper or anything else?
