What would I need to do to make 37's fit??
Old Sep 2, 2010 | 05:23 PM
jhiero's Avatar
Default What would I need to do to make 37's fit??
I had a friend of mine give me two BFG t/a ko 37/12.50/17's like new still have the tits on the sidewalls. I would be putting them on stock moab wheels.I know that its probably not going to work but its worth a shot.
Old Sep 2, 2010 | 07:07 PM
jhiero's Avatar
will they fit on the stock rubi wheels??? I really dont do any hardcore wheeling
Old Sep 2, 2010 | 07:28 PM
jhiero's Avatar
Originally Posted by planman
flat flares
2.5" rear extended bumpstops
1" front extended bumpstops
1" body lift
Spidertrax wheel spacers
How-to thread:
https://www.jk-forum.com/forums/show...uspension-lift.
where do I find the extended bumpstops. Are the flat fenders a must? also im running 4:10 gears with a auto transmission.Would I be better off just putting on 33's or 35's?
Old Sep 2, 2010 | 07:41 PM
fadeout's Avatar
You'll need the room the flat flares open up or you could just chop your own. Northridge should probably have the extended bumpstops. I'd recommend "C" gussets too for the 37's. No they're not necessary but it couldn't hurt.
Old Sep 2, 2010 | 08:01 PM
jeeperaf's Avatar
Since you aren't going to wheel hard, I believe you can get away with flat fenders and a 3" lift. I'd also gusset the c-arms and sleeve (outer is fine) the axle for long-term strength.
Best of luck...
