What would you do??? Driving myself NUTS!!!!!!!!!
Old Aug 31, 2011 | 06:42 AM
JeepNoob10's Avatar
Default What would you do??? Driving myself NUTS!!!!!!!!!
Im lifting my 11 JKU and was all set to go with a 4.5" lift with 35's but after looking around at some jk's running a 3" lift with 35's Im wondering if the 4.5 will be too much.
For me I like the look of a stocky stance and for the tires to fill the wheel wells. Any advice/suggestions/thoughts is appreciated.
By the way the chance of me going to 37's at some point is VERY VERY slim. If I thought there was even a slight chance of that Id stay with the 4.5 without a doubt.
Old Aug 31, 2011 | 06:44 AM
wayoflife's Avatar
JK-Forum Founder
4.5" of lift is A LOT OF LIFT and, in my opinion, way too much for just 35's. i would stick with a 3"-3.5" lift as it is really all you'll need to clear 35's and a much better way to go. trust me, this is coming from someone who's run both setups more than once.
Old Aug 31, 2011 | 06:45 AM
raidue's Avatar
Yeah 4.5" would give u lots of room in the wheel wells with 35s. Too much room IMHO...
All U really need to run 35s is a good 2.5" lift. The TF 2.5" which I'm running yielded about 3.25".
Old Aug 31, 2011 | 06:50 AM
Markdsv's Avatar
Remember the higher you go the more the car differs from it stock characteristics, anything above 4 requires also driveshafts etc. Also remember that a 4.5" lift in reality might be more, I wouldn't be surprised if you end up with 5.5" and indeed 35's will look small. My two cents
Old Aug 31, 2011 | 06:51 AM
Merlin4979's Avatar
If you're wanting to keep the stance low, you can get away with just using flat fenders and no lift for a set of 35's.
If you're set on a lift - then as was said above - all you need is a 2.5" lift. Check out Teraflex and Rock Krawler for some great quality setups.
Old Aug 31, 2011 | 06:55 AM
jeep2007's Avatar
Definitely stay 2.5 to 3...JKs are not like a TJ or YJ.
Old Aug 31, 2011 | 06:57 AM
wayoflife's Avatar
JK-Forum Founder
exactly! i think a lot of people remember the days of the old TJ and YJ and assume that the same should apply on the JK - no so at all.
JeepNoob10's Avatar
Thanks guys I appreciate the advice. The more I look and think about it I think the 3 is the way to go for me.
I was driving myself crazy thinking about things like how much would adding an aftermarket bumper with a winch affect the height of the front end. The fab fours bumper Im looking at is only 80lbs and I havent decided on a winch yet but these are just the things that have been going through my head. I want to try and make the right choices first time around.
thanks again
