what year jks have "command trac"?
Old Dec 12, 2012 | 06:40 PM
kny21's Avatar
Originally Posted by ronjenx
True.
I think they started calling the part-time t-case Command-Trac back in the early '80s.
That's what it was called on my '88 XJ and '88 MJ.
^ this...
"command-trac" = part time 4wd
"select-trac" = full time 4wd
Select was just 4h without locked hubs
Older Cherokees & Grands with the better tcase had select also had command. Some Grands had quadra-trac which was only select & 4lo, no 2h I believe (been awhile).
Old Dec 12, 2012 | 06:45 PM
idiotec's Avatar
Originally Posted by kny21
^ this...
And then they call the Rubi system "Rock-Trac" which just means the different TC and Lockers. Marketing names
Old Dec 12, 2012 | 06:51 PM
ronjenx's Avatar
What do you mean "without locked hubs"?
Select-Trac allowed 4hi on pavement by having a viscous coupler between the front and rear drive shafts in the t-case.
Old Dec 13, 2012 | 04:45 PM
Shadow's_Jeep's Avatar
^ this...
There is also the Selec-Trac II, which run's in 2 wheel drive with Active Full-Time 4WD in Hi , an 4WD in Low-Loc. It was the optional transfer case in the 08-12 Liberty. It's what my wife's 08 Liberty Limited has.
